Rear subframe differences
Old May 16, 2013 | 04:16 AM
yorkies2k's Avatar
Default Rear subframe differences
I'm replacing the rear subframe on my uk my2001 car. I'm considering putting a later model subframe on as I believe the changes made to the suspension pick up points made it a little less snappy? Am I correct in thinking this is a direct bolt up replacement apart from the upper wishbones that are different? Anyone else done this and noticed much difference?
Old May 16, 2013 | 12:47 PM
yorkies2k's Avatar
No one ??
Old May 16, 2013 | 02:14 PM
davemr2's Avatar
Am sure someone will tell you,
Id think that its a direct bolt for the main subframe the suspension side of thing will be different so you'd need facelift wishbones etc but i could be wrong
Old May 16, 2013 | 10:18 PM
Carbon S2K's Avatar
Dixon did the swap on his black s2000.I don't think he needed facelift wishbones tho? But best ask him about it to be 100% .....have a look on his build thread bud
Old May 16, 2013 | 10:23 PM
Joeh's Avatar
The older wishbones wont fit, the mounting points are further apart
Also you will need longer bolts
Old May 16, 2013 | 10:29 PM
yorkies2k's Avatar
Read it, it was that what got me thinkinking of doing it. He doesn't say if its a direct bolt on or if he had to modify it though but did mention the upper wishbones been different which I knew about.
It was more if/how much of an improvement it would be that I wanted to find out aswell. I'm guessing its not a swop people would normally do unless they need to.
Old May 16, 2013 | 10:30 PM
yorkies2k's Avatar
Just for the upper wishbones?
Old May 16, 2013 | 10:54 PM
bow1build's Avatar
I have a full set of suspension arms and sub frames you are more than welcome to take measurements off mine as i was changing my 2003 car to the newer 2008 parts.The poly bushes are different on 2 suspension arms and the mounting points are different on the back ones.
Old May 16, 2013 | 10:55 PM
bow1build's Avatar
Jake89
Sep 11, 2015 09:39 AM
GreenmanS2000
Feb 25, 2015 10:59 AM
arsenal
Jul 8, 2014 07:52 AM
ShirleyTemple
Nov 6, 2009 12:10 PM
caprighia
Sep 21, 2008 11:58 AM
