Removing CD cassette from CD changer
Old Nov 30, 2003 | 06:41 AM
Lurking Lawyer's Avatar
Default Removing CD cassette from CD changer
Craig came round last weekend to help me make a start on removing my CD changer prior to p/x-ing my car against an 04 in a few weeks. After a bit of a game getting a recalcitrant screw out, we were able to get the head unit out and unplug the CD changer cable.
Except I completely forgot that, without power, I wouldn't be able to remove the CD cartridge to retrieve my CDs
I know someone has posted about this in the past - a quick search didn't throw up the thread though. Anyone out there know a more convenient way of getting the cartridge out without having to take head unit out again and plugging the cable back in?
Alternatively, is there anyone within a reasonable distance with a Honda OEM CD changer (not sure whether it has to be 02 specific, or whether any year would do) who would be prepared to meet up with me so I can "borrow" your connection to temporarily power mine up and extract the cartridge - I'd just need to unplug your changer and plug the lead into mine.
Old Nov 30, 2003 | 07:23 AM
Bassoctopus's Avatar
Mark,
There is normally a clip that holds the changer in. On my Alpine kit slide a long knife underneath the cartridge which pushes the spring loaded clip down and the cartridge pops out. Of course yours might be slightly different put it's worth a try.
Alternatively unscrew the changer's outer case.
Or finally pop down to your local car hifi store which should know how to release it.
Old Nov 30, 2003 | 07:26 AM
eSeM's Avatar
Mark, if it is Matchbox 20 in the changer I would just leave it
No! there isn't an easy way.
I did this recently when I removed my minidisc head and changer. I connected the Head to the Changer and used a 12v source to power up the head to power up the changer so that I could remove my CDs.
You would also be able to power up the changer from someone that had an Alpine M-Bus changer installed as the connector is the same and they use the same power pins.
If you bring it along to the Herts meet on Thursday I am sure you could find somjeone to help.
Old Nov 30, 2003 | 08:04 AM
AquilaEagle's Avatar
Administrator
MT what the hell is a recalcitrant screw ?
Old Nov 30, 2003 | 08:13 AM
The bugger refused to come out, notwithstanding da paper lawyer's best efforts - it just span in the socket.
Thanks for the advice, Steven and Neil - I'll try a knife. Failing that, I'll have to get together with someone who has either an OEM or Alpine changer. Can't remember whether Craig has a changer to go with his Alpine HU - if so, that would probably be the easiest option.
Old Nov 30, 2003 | 08:14 AM
AdrianEagle's Avatar
A hard one to get out!
Sort of like a bird with very strong legs!
Old Nov 30, 2003 | 08:15 AM
Paper Lawyer's Avatar
I'd lock Jenny, her screwdriver and the cartridge in the bathroom and tell her she ain't coming out until she's either (a) got the CDs out; or (b) built a cabbage-firing tank capable of blowing you into submission (in true A-team style)
errr, is "blow" the right verb?
Old Nov 30, 2003 | 08:18 AM
I found your drill bit, BTW, Craig.
And judging from your sig, no Alpine changer I can get a "jump" off. Ho hum.
Old Nov 30, 2003 | 08:26 AM
Afraid not, but I've got the OEM HU - I wonder how easy it would be to get some juice into it....probably easier to take the cassette apart, although I agree with the knife suggestion.
