Removing cd changer
Does anyone know an easy way to remove the bracket for the cd changer
It appears to be held in by 2bolts and a clip
The two bolts come out no problem at all but that fin clip...
It is metal completely flat and is the third anchor point ( so awkward to get at)
Any help or advice greatly appreciated before I rip a hole in the boot
I did this a couple of days ago. The two from inside the boot are straight forward as you've discovered. The third is a round headed bolt. The nut on the other side of this can be accessed fairly easily from underneath the car - no need to jack the car up or remove the exhaust, but the silencer will get in your way slightly, and you need a suitably sized socket/ratchet/extension to make it easy for yourself.
The nut on mine sheared off after a couple of turns.
Gary
Gary
Belated Thanks chaps
Undoing the bolt while lying on the road with cars whizzing past my head was "exciting" to say the least
Mine too sheared. Still, saved a lot of turning
reds2k1
Apr 9, 2004 03:12 PM
