Replacing the side light bulb!
Old Feb 28, 2008 | 10:14 AM
  #21
motogp1's Avatar
Originally Posted by RISLAR,Feb 27 2008, 09:49 PM
Get your finger out and i want them fitted by the weekend, you have been warned
yes dad
Old Feb 28, 2008 | 11:35 AM
  #22
RISLAR's Avatar
Originally Posted by motogp1,Feb 28 2008, 07:14 PM
yes dad
Old Mar 4, 2008 | 03:18 AM
  #23
zagamuffin's Avatar
Originally Posted by MC_BLADE,Feb 27 2008, 11:58 AM
LED's should not die , there supposed to last years!
just got this reply from led supplier when i asked about leds lasting much longer than standard bulbs......
[COLOR=red][B]Rob who told you that
Old Mar 4, 2008 | 06:44 AM
  #24
moff's Avatar
I will never buy LED's again.
I went through 3 pairs of sidelughts in 10-12 months, a complete load of rubbish.
Yep, they look better than the yellow normal bulb glow, but they are useless.
I have gone back to the OEM sidelights which work perfectly.
Old Mar 4, 2008 | 06:50 AM
  #25
*AL*'s Avatar
Last weekend i fitted LEDs as a rear marker light to the original units, subtle but nice.Easy to wire and easy to remove if not wanted.Used 2 LEDs per side.
Old Mar 5, 2008 | 03:25 AM
  #26
zagamuffin's Avatar
nice idea,holes there already ??
Old Mar 5, 2008 | 05:22 AM
  #27
tiger289's Avatar
I got the silver indicator bulbs and they sent me the wrong led's so put in indicator bulbs then when correct led's came put them in then a few weeks later led's fail so put the orignal back in
The silver indicator bulbs do work well and look
Old Mar 5, 2008 | 06:15 AM
  #28
*AL*'s Avatar
No holes there aleady, but there is a marked 'circle' where i believe the US models fit a bulb.
The LEDs i used are red 'push in' type which already accept a 12V feed so no need for resistors .Just needed to drill a 8mm hole which take seconds, and the head of the LED just pushes snuggly in the unit hole, then neatly connect the LED wires to the rear side light power.It takes longer to remove the rear light unit and you can also give the panels behind a bit of a clean.
Old Mar 5, 2008 | 06:25 AM
  #29
mikey k's Avatar
Originally Posted by zagamuffin,Feb 27 2008, 09:19 PM
must mail led supplier as i also had a full set die
zaga
I've killed three sets and am now running blue tinted bulbs to save my fingers
Old Mar 5, 2008 | 06:42 AM
  #30
RISLAR's Avatar
Oh bugger, now i find out!!!
