Roll cage
I assume so. However I would doubt it'll fit. The mounting bracket positions, roof clearance, trim fitment etc would all clash. Although the top of a cage may look similar, the footprint will be hugely different. I bet it'll be cheaper to have one made up.
Also bare in mind. Riding around in a road car with a cage can be dangerous unless you wear a helmet all the time. One side impact and your temple is going to smash against a very unforgiving metal frame. Looks wise it's always down to personal preference, however I would recommend not to.
I've got soft squishy roll bar padding near driver and passenger ' temple crush bars' and some hard FIA stuff for use with helmets.
One thing to note is even with a perfect fitting rollcage the liveable space inside is severely reduced, more so once padding is added. I wouldn't bother with a cage unless youre planning on going nuts on track or require it for competition.
