Is this rust anything to worry about?
Old Nov 2, 2017 | 10:48 AM
aleksboch's Avatar
Default Is this rust anything to worry about?
There's a 2004 model I am interested in purchasing however it has some corrosion in places. Is any of this quite serious? Apart from this the car looks solid. Thanks for any opinions.
Attached some pics below.
Old Nov 2, 2017 | 10:52 AM
Nick Graves's Avatar
Back end is pretty rusty - hole in the chassis leg?
That seam sealant on the front inners is messy - sloppy accident repair, probably. Hence the rust...
Old Nov 2, 2017 | 11:04 AM
aleksboch's Avatar
Both side have this 'hole' in the back end.
This is the car in question.
https://www.autotrader.co.uk/classif...01710240611058
Old Nov 2, 2017 | 11:13 AM
Daytona-Dave's Avatar
All perfectly normal for a 13yr old car that hasn't being owned by a true enthusiast and nothing that a few hours elbow grease can't sort out , you should be looking at the lower part of the rear sills and the rear of the wheel arches the two holes in the chassis are normal and meant to be there
, but i'd also want to know why the wiring has being messed with and taped up and clad in wire tidy on the n/s
Old Nov 2, 2017 | 11:19 AM
aleksboch's Avatar
Frustratingly hard to find a genuine s2k for sale nowadays that doesn't have something wrong with it.
Old Nov 2, 2017 | 11:29 AM
You'll find rust in some form on most S2000 it's an old motor now and most will have some problem or another it's how much work your prepared to put in to make it as good as want, if your looking for a perfect one you'll have a long journey and have to dig a lot deeper than this one is priced at,
Old Nov 2, 2017 | 11:43 AM
miloking's Avatar
bro that seam sealant is factory.... i have 3 s2000 and they all have the same sloppy sealant...
on the other hand its a lot of rust for 10k price. ..even if it has mugen intake and exhaust
Old Nov 2, 2017 | 12:08 PM
Stevo071077's Avatar
It has what appears to be a pre-facelift exhaust with circular (rather than oval) tips..?
I think in isolation, the rust shouldn't be a firm barrier to purchase for a car of this age.
Also, is that Oil filter OEM? If not I'd prefer it to be if I was going to drive it hard.
Old Nov 2, 2017 | 12:22 PM
Little Bob's Avatar
That does look pretty rusty underneath, is that typical for a 2004 car?
i guess it has been kept outside rather than in a garage.
Also to add, with that much rust underneath did you take a good close look at the arches?
Old Nov 2, 2017 | 01:05 PM
Sipha's Avatar
My 2004 has no rust at all in any of those places so it definately isn't 'normal'. The sealant on the inside of the arch is exactly the same on mine though, pretty sure its normal.
