S Pulling to the left when throttle on
Yep one of your wheels will be a lot hotter after a drive! Unless it's stuck in the off position which is v unlikely.
You can check the fronts by jacking the car up and spinning the wheel - if it's not free your caliper is stuck. Rears are harder to check because the diff means it won't freewheel when you spin it. Wheel off I guess.
There was a recent post from Le Sau on this subject. Alan was suffering from similar issues after a new set of rears and ended up having Chris at centre gravity taking a look. Turned out that the rears were from different batches, identified by reading the DOT codes on the tyres. I'll try and dig out his post
Here it is
https://www.s2ki.com/s2000/topic/992...t__p__22176513
Here it is
