S2000 AP brake kit
Old Jan 1, 2012 | 03:09 AM
dreamkev's Avatar
Default S2000 AP brake kit
Hiya guys am seriously considering getting this brake kit but still not sure if it will clear my aftermarket 17" wheels with an +52 offset? Has anyone here have any experience with this s2k ap brake kit?
Cheers
Old Jan 1, 2012 | 03:16 AM
D2 TEX's Avatar
What wheels have you got? Different wheels have different clearances.
Old Jan 1, 2012 | 03:42 AM
chrisr111's Avatar
Kev, they will not fit behind your GPs without using spacers.
Chris.
Old Jan 1, 2012 | 03:57 AM
MB's Avatar
MB
Member
Hi Kev, having looked down this route before and decided its not needed on the S, have you thought of a Dixcel setup?
Old Jan 1, 2012 | 05:16 AM
dreamkev's Avatar
But on the ap website, it says aftermarket 17"?? Well I already have a fair of tarox brake kit but thought I'll like a change!!! Plus the ap's would look allot better
Old Jan 1, 2012 | 05:39 AM
Nick Graves's Avatar
That's because all aftermarkets apart from the decent wheels are the wrong offset! It's the sort of bullshit comment you get on many websites. AP ought to be done under the Trades Descriptions Act.
You need to re-phrase the question; which BB kits WILL fit behind my proper wheels?
Old Jan 1, 2012 | 06:32 AM
chrisr111's Avatar
The statement on AP's website is correct, but not specific.
There are only a handful of aftermarket wheels with the correct offset and spoke design that allow big calipers to be used on the S2000 (without spacers).
S2000 specific Mugen GPs do not meet the above requirements.
Chris.
Old Jan 1, 2012 | 07:04 AM
Turtle's Avatar
You need to check the actual profile of the spokes. AP often have fitting templates for their kits - you print them out, stick on card, cut round the outline and "fit" inside your wheel to see if it will clear or not. No idea if they have an S2000 one, but you could ask.
The AP Racing kit for the S2000 was originally measured on a Japanese race car using rather wide wheels. While they did use a thinner disc (26mm) than they would have normally, it is still very tight on clearance. You're likely to struggle to find many wheels that will fit while keeping a sensible offset.
The suspension design of the S2000 is such that it limits how much the disc plane can be moved. Makes it very tricky to fit a decently stiff caliper in.
-Brian.
Old Jan 1, 2012 | 09:06 AM
mr-pitts's Avatar
Cheers
Check out the Helpeformance build,their caliper is really close to the wheel.
Old Jan 1, 2012 | 10:34 AM
HEL Performance's Avatar
But ours is completely different to the std AP S2000 kit so dont! Our caliper is a big 6 pot, and discs 362mm!!
Originally Posted by mr-pitts
Cheers
