S2000 Headlamp
Has anyone had a headlamp go on them ??
This is not an accident damage - just a blown headlamp bulb I think !
Is it a simple bulb change or do you have to go to the dealer & is it covered under warranty ??
Any ideas as to the cost it ??
Thanks
Bharat
Thanks
Bharat
Sorry, but IIRC that is the approx price..gas discharge bulbs are well expensive..the dealer needs to fit them due to the potentially fatal voltages invlved with the circuits that power them...
they are supposed to last a while, so you could try a warranty claim...
One of mine went and when the dealer saw how much they were he swapped them and discovered it was a loose connection. To quote from Arkwright get them to j j j jiggle it a bit before they replace.
I would take it to the dealer and request it to be carried out under warranty. There is more to the HID system than the bulb. It could be the inverter or ignitor instead of the bulb. Have you checked the fuse? There is one for each side, they feed the corresponding high beam as well as the HID, so should be easy to check.
