sandblasting tct
Old Jan 21, 2011 | 12:42 AM
thewiseboatmaker's Avatar
Default sandblasting tct
looking for someone who can sandblast a tct wormgear for me..
trying to get hold of matt as i know he can, but think he might be away..
can anyone else do this..?
any help muchos appreciated
Phil.
Old Jan 21, 2011 | 01:05 AM
eSeM's Avatar
Rough sandpaper and/or a wire brush will do the same job.
Old Jan 21, 2011 | 01:07 AM
i can manage taking it in and out of the car.. but not the extent of pulling the thing apart to get to the worm gear for sandblasting.. i know matt can prob help but he doesn't seem to be about at the mo..
Old Jan 21, 2011 | 01:27 AM
Dembo's Avatar
Once you take it out of the car the thing will pretty much fall apart in front of you.
I used valve paste on mine, which seemed to have the same effect (even though it didn't actually stop my ticking ).
Old Jan 21, 2011 | 01:28 AM
Squeak's Avatar
Matt is away but I will ask him when I speak to him next
Old Jan 21, 2011 | 01:30 AM
Wobbly's Avatar
Can someone explain why sand blasting the worm gear fixes the TCT? I can't think of any reason why
Old Jan 21, 2011 | 01:34 AM
TangoVTEC's Avatar
I will do the tct sanding for ya mate. Although it'll only be the sandpaper method, not sandblasting.
I will add that I have done a few now, including mine over a year ago without reoccurance.
Old Jan 21, 2011 | 01:37 AM
eSeM's Avatar
Or even before you take it out of the car .....
Last time I removed the TCT I removed the bolts and the TCT wouldn't move so I went into my garage to find a screwdriver ...... when I returned the TCT was in bits on my driveway
Old Jan 21, 2011 | 01:42 AM
Dembo's Avatar
As far as I can work out, the worm gear should allow the piston to come out under oil pressure, but when the oil pressure drops (i.e. at idle), the tension from the chain shouldn't be enough to push the piston back in against the worm gear. But the worm gear becomes too smooth and shiny, and there isn't enough friction to stop the piston moving back in, hence lack of tension and rattle.
It's much the same as the way the rear brakes work.
Old Jan 21, 2011 | 01:46 AM
S2000_FUN's Avatar
Sandblasting the worm gear the rough surface which will be created will help to keep oil much more in the worm gear due to friction.
If i am correct you need also to sandblast and the inside of the piston for better friction
