seized bolts
Hi Everyone
Just after some advice, just had my car hunter aligned, the guy said that he could not adjust the passenger side rear as the bush was seized and is way out of alignment, what can i do to fix this, what do i have to order? any ideas? |
Originally Posted by Fergal
(Post 24360523)
Hi Everyone
If it's a rear they can sometimes be freed off with the right gear
Not had the rear sieze, is it just camber and toe adjustment so two bolts?
worst case if you cant find a mechanical superman like Ray is you cut them out, grease the shit out of your new uns and pop them in |
Use a marine grease, or something like Wurth AL1100, which will protect them properly long term.
lol, the "right gear" is a lump hammer :) it's the only bush bolt you can get a decent swing angle to hit. Seriously though if you don't want to ruin the bolt like I did then you could use one of those ball joint presses that looks like a G-cramp to press the bolt out.
I greased mine with Corrosion Block ACF-50 Corrosion Block - Anti-Corrosion compound, oil and grease and that's done the trick for a number of years now with no re-greasing. |
Originally Posted by Nottm_S2
(Post 24360566)
(Post 24360700)
Hi, yes it is the camber and toe, will try and look which bolts i need, thanks
they are not cheap but not crazy money |
seized bolts
Thanks for your answer guys, have e mailed Hendy for costs.
if your cutting them out you'll need all new bushes as well
