Serious, serious engine problem
Old Jul 18, 2011 | 08:23 AM
Cudder's Avatar
I've spent half the day on the phone, mostly to Consumer Direct and Citizen's Advice. I haven't arranged for it to be taken to a mechanic yet, as i've been in touch with the garage.
That 6 months warranty thing refers to a 'Burden of Proof' that lies with the seller, it means they have to prove the car didn't have this problem at the time of the sale and that it was unforseeable. I explained the situation to the garage, they asked about the oil etc. which i assured them was fine. The guy on the phone told me he'd pass it on to his manager and to call them back in the morning to "see where we go from here". Which is quite promising really, it's better than a straight no.
So maybe i'll get somewhere (:
Old Jul 18, 2011 | 08:37 AM
lower's Avatar
Don't pin your hopes on this. You'll have a legal fight on your hands and you'll need to be prepared for an extended and expensive battle unless the garage decides to roll over.
They might have to prove that the car was fine at time of sale, but you'd have to prove that you hadn't let it run low on oil or that you haven't over revved it. Neither of those is easy for you to prove either.
The easiest option is going to be for you to start looking for a replacement engine.
Old Jul 18, 2011 | 09:59 AM
Cudder's Avatar
Well when the AA came out to me, they checked it all and confirmed that the oil and everything was fine. I was even assured it wasn't anything I've done, or could've done to prevent it.
I'm not going to pin my hopes on this, but if there's a chance it can be refunded or repaired then i'd be daft not to go for it. I can't afford to just go engine shopping, so if this didn't work out i'd have start by getting the engine looked at to find out what the problem is for sure.
If all else fails, i'll have to start playing the lottery more frequently...
Old Jul 18, 2011 | 10:45 AM
Nick Graves's Avatar
Sorry to hear it.
If it were a bent valve, the lack of compression ought to give you a misfire CEL. You'd know if it were only running on three pots from the rhythm.
I should say either the piston rings are picking up, or a bearing has ran. Both are common issues in the car and probably due to oils starvation/aeration (typically a track day) in its former life.
Obviously, don't run it like that - it will let go. A repair (or a new engine) might be possible, but you have some patient negotiation to go through - firm but polite!
Old Jul 19, 2011 | 09:35 AM
fluffyninja's Avatar
I'm with Mr. Graves on this one. Description sounds like it's been chewing on a big end bearing for a little while and has finally spun the bearing and is now banging it's t!ts off.
The usual suspects are:
1. Low oil level (doens't have to be low at the time of failure, could have been done prior to that and then taken time for the damage to become critical)
2. Old oil (can be enough oil in the engine but if its old, knackered and not lubricating any more)
3. Filter not replaced during service (if the filter isn't changed and blocks up they have a bypass channel to allow oil to get there - some is better than none - but would allow contaminated oil to get to the bearings)
4. Low oil pressure (breach in oil passageway/open relief valve in the pump or similar)
Probably too old an engine for it to be something like dirt/debris/swarf or similar from the build process
Old Jul 22, 2011 | 08:39 AM
rob2.2's Avatar
Banned
hi mate
have you had it looked at any more?
do you now know what's up with it?
Old Jul 22, 2011 | 09:37 AM
Ultra_Nexus's Avatar
100%
Here is a spun bearing on a D16 I did a few years ago:
Symptoms are identical.
Old Jul 22, 2011 | 11:24 AM
That'd be it; the big end journal should be smooth like the main adjacent to it.
The starvation causes massive heat & the bearing shell welds to the journal & in extremis, spins in the conrod.
Old Jul 24, 2011 | 07:09 AM
Cudder's Avatar
Hi folks, here's a quick update. It's been taken to a garage for an engineers report, at the seller's expense. I spoke to them and they told me it's knocked the crank out (or something like that). They asked me the usual, ran on low oil, over revved etc which it hasn't been. I'm calling again on Monday to find out the full problem, and how cooperative the seller's going to be out getting it fixed. But legally i do have a good chance. I'll let you know how I get on, thanks guys.
Old Jul 24, 2011 | 07:19 AM
richmc's Avatar
Theoreticly can't over rev it, it has a limiter,this also works when the engine is cold limiting the revs even lower, ego you can't over rev it, unless you miss a gear coming down.
