Shiny Discs
Old Jan 18, 2005 | 01:24 AM
CiderBoy's Avatar
Default Shiny Discs
Hi,
I got my MY02 S2k in November and it's discs were lacking in shine. I assumed that this was normal for a car that had not been used much recently and was expecting the rust to disappear once I started to use the car. However, they still 'ain't pretty! Has any one got any advice for cleaning them up? Are there any specific products for this out there?
Thanks in advance!
Nick
Old Jan 18, 2005 | 01:35 AM
Richieh's Avatar
Harsh braking at high speed works for me. Today's not really the best weather for that, so be careful
Old Jan 18, 2005 | 02:24 AM
simonprelude's Avatar
Wire brush (not on the braking surface itself) will help, they will inevitably rust again though, I have black diamond discs on the prelude and they don't seem to suffer as bad, not sure if they are available for the S2000 though. Think they are anodized / treated to stop them rusting.
Old Jan 18, 2005 | 10:32 AM
AquilaEagle's Avatar
Administrator
just brake more they will show a film of rust even after overnight parking, not to worry about though IMO
Old Jan 18, 2005 | 10:58 AM
CiderBoy's Avatar
Thanks guys. Guess they will look better once the summer comes: heavy braking and less moisture!
Nick
Old Jan 18, 2005 | 10:43 PM
Kiteland's Avatar
A mechanic friend or mine once advised that if you wanted to limit the amount of overnight rusting (esp if your car isn
Old Jan 18, 2005 | 11:21 PM
euan's Avatar
Problem can get worse if you only use the car intermittently, ie just at weekends. Then the rust gets time to build up as it isn't being cleaned off each day in normal driving.
I've ended up replacing rear discs on all my previous cars prematurely because of this. Happened with the S too - discs badly corroded, but replaced under warranty.
Old Jan 19, 2005 | 03:31 AM
Craigyboy's Avatar
Wait till a dry day, go for a drive, brake a lot, get them nice and shiny, then apply a good thick layer of clear grease to the brake discs. This will keep the water off, and stop the going rusty.
Job's a good un'
Old Jan 19, 2005 | 04:11 AM
Noony's Avatar
It wouldn't surprise me if someone tries that you know.
I have seen painted discs before now, which must make deceleration both exciting and fragrant !
Old Jan 19, 2005 | 04:17 AM
rmotegi's Avatar
Yep - greasing your discs really does stop any rust problems.
Also has the uncanny knack of getting rid of any nasty unwanted deceleration if you hit the middle pedal. Car just sails on unperturbed.
Net result - you go even faster!
