Shrill whistle
Old May 17, 2016 | 12:14 PM
AXO 5's Avatar
Default Shrill whistle
My s2000 has developed a noise best described as a shrill whistle when accelerating .
I vaguely remember reading a similar post but can't remember where or what was said. With the roof up you can barely hear it.
I haven't taken it anywhere regarding this issue yet but any help much appreciated.
Old May 17, 2016 | 12:52 PM
mikefifth's Avatar
Intake.
Fipk does this
Old May 17, 2016 | 01:27 PM
AXO 5's Avatar
It has standard intake.
Old May 17, 2016 | 02:33 PM
mikefifth's Avatar
Cars f@#ked then
Old May 17, 2016 | 09:54 PM
richmc's Avatar
Originally Posted by mikefifth
Cars f@#ked then
Trust you Mike!
Post up a video, might be something silly like the aux belt slipping.
Old May 18, 2016 | 12:07 AM
kw_21's Avatar
This may help
https://www.s2ki.com/s2000/topic/875...#entry20682660
Old May 18, 2016 | 12:37 AM
User 4225's Avatar
I'd be inclined to go with intake/throttle body whistle. I've heard cracked exhaust manifolds cause a high pitched whistle before so worth checking that to be sure you've not got a cracked primary on there.
Old May 19, 2016 | 11:53 PM
mikey k's Avatar
Pulley bearing?
Old May 20, 2016 | 12:39 AM
Flukez's Avatar
You've got me paranoid now. I can near a faint noise which is akin to a swift robotic arm. A *swoosh* kind of sound upon accelerating.
Hearing (https://www.youtube.com/watch?v=ZKfhW6JG3C8#t=22s) sounds a bit extreme, no?
I guess the bigger question is it causing any damage and does it require an immediate fix. I reckon that's a no...
If you manage to track down the culprit, please keep me posted.
Good luck!
Old May 23, 2016 | 04:38 AM
unclefester's Avatar
You need to clean out your IACV and throttle butterfly although a slight whistle on part throttle is just 'one of those things' on this car.
Forziii
Aug 10, 2015 08:07 AM
tolin1124
Aug 28, 2008 10:32 PM
rcodea
Dec 27, 2007 06:22 PM
Jacques79
Nov 28, 2007 08:12 AM
