Side diffusers fitted!
Ok guys so got the first set of Tarmac Sportz new side diffusers through last week but weather and commitments mean I haven't been able to fit!
Got myself some no more nails 125kg tape and 4 self tappers with large washers for each side to keep them on... Simple to fit and don't obscure the jacking points fitting over the chassis hole rubbers.
You should take out those screws one at a time and put some silicone sealant in the hole and on the threads. Anytime you drill a hole in sheet metal you need to do your best to seal it from the elements. They look good.
Will re fit the screws but waiting for some better weather to do it on the threads Just been difficult with weather like this, also they are screwed through the no more nails tape so should be protected for now.
