Sidelights
When I looked into getting some, I just trawled through the following threads as there is alot of info on what to avoid, potential mods for some of the LEDs and where to buy them from.
https://www.s2ki.com/search/forums?forum=25...=LED+sidelights
I think Ajs_s2k has had more luck than most with these to date, give him a shout to see which ones he's got as ALOT of them are prone to failure.
Try these 9 LED Cluster Bulb
I have them on my front sidelights and rear number plate bulb (although these area a little big for the rears)
I had the front LED for over 2 years and they are still going strong!
Juts bear in mind the price is for 1 but at
Originally Posted by Spykee,Jul 19 2009, 12:15 PM
PM sent. Are they a bit of a bitch to fit? I can't even see the back of the headlights so I'm guessing its a wheel arch liner removal job?
They are okay to fit, it's in the handbook, takes around 5 mins each side. You don't need to remove all of arch lining, just one clip, wheels on full lock then reach in and swap.
