Singlepipe exhaust tailpipe
Old Feb 21, 2011 | 12:54 PM
s2konroids's Avatar
Default Singlepipe exhaust tailpipe
I have a 5zigen pro spec 3 singlepipe exhaust (straight cut exit NOT angled), its a bit old now but structurally perfect being made out of stainless steel with an 'inconel' tip. The exhaust doesn't have much drone, its a nice sounding civilised exhaust, whilst being lightweight and adding power - so i don't want to get rid of it really (Having owned previously about 5 exhausts on the S). I also have a single-pipe exhaust cap on my car which compliments the singlepipe.
The problem is the blue'ish/purple'ish burnt look has significantly dulled down over time and no amount of cleaning/polishing will restore it.
A while ago I attempted a DIY and rubbed down the tailpipe and effectively polished the old burnt look off and re-burnt but with limited success (used blow torch etc), the blue look is there, more of it but duller than before .
I like the burnt look, but not a great fan of the slash cut. So the idea would be cut 90% of the end off and either weld on a 'new burnt look slash tailpipe', 'rolled tip burnt tailpipe', plain tailpipe or another design?
Its a shame getting rid of the iconel, but the current looks annoys me, well more of a niggle .
I guess it could be reburnt again - but cant be arsed TBH .
What do you think?, suggestions?
Thanks
A few pictures, not my car but examples.
Old Feb 21, 2011 | 01:56 PM
exalto's Avatar
It it niggles that much, you will eventually be arsed so get it reburned by a pro. Surely a lot less hassle than mixing and matching?
And you keep your inconel.
But if the slash bugs you, then...
Old Feb 21, 2011 | 02:00 PM
s2konroids's Avatar
Where i live there isn't many pro's. There is one place but even he said that TBH he wasn't sure about re-burning, as he tried it with stainless steel and it was a poor finish.
He said he can weld a tip on no problem, and fabricate but would have to look at ordering a burnt tip in (as he doesn't stock any) and thus weld.
Old Feb 21, 2011 | 11:20 PM
Benjamico's Avatar
I've got the same exhaust on mine... The tailpipe design is the worst part of what is otherwise an brilliant exhaust.
Modifying it would seem like a crime though!
Old Feb 22, 2011 | 01:13 AM
WinFreak's Avatar
Polish it off and forget about the blue burnt tip... its 2011!
Old Feb 22, 2011 | 03:19 AM
razzele's Avatar
Maybe try getting it hotter- have you tried oxyacetylene ?
(could be an idea to have a replacement tip on standby!)
Old Feb 22, 2011 | 03:25 AM
chrisr111's Avatar
You need to use MAPP gas
Chris.
Old Feb 22, 2011 | 03:31 AM
razzele's Avatar
https://www.s2ki.com/forums/index.ph...ic=356084&st=0
maybe of interest
Old Feb 22, 2011 | 03:59 AM
s2konroids's Avatar
I used butane or propane, where can I buy mapp gas? Is mapp gas just in a container. I have bought a proper polishing kit so might get a better finish.
Old Feb 22, 2011 | 04:09 AM
Itchy Dick's Avatar
Is the blue effect not gained by heating the tip up and then rapidly cooling it in oil?
