Solid steering rack bushes
Just fitted. Took about an hour and a half (with cig breaks).
They seem to increase the steering feel slightly when driving in a spirited manner but certainly not a dramatic change although I've only had them in for 10 miles or so. I need to go and find a good mix of roads when it dries out a bit really.
We will see how they go over the next few months.
My old bushes seemed In decent condition mind you. I've had these sitting around for a year or so and decided to give them a try.
I'll monitor closely as they are solid alloy so may cause issues in the future but we will see what happens.
150 miles in and I like 'em.
A bit more vibration through the steering wheel but a more direct connected feel to what the front end is doing. It's a subtle difference but noticeable. No play in the rack whatsoever. I can only liken it to how the original mini's steering felt although lighter obviously due to the power steering.
Will see how they feel after time but I have more confidence as a result in long fast sweeping corners although that could well be a placebo effect.
I think I might give dixons subframe spacer/bush thingys a try next out of curiosity.
Bloody ell ! Gary you seem to like keeping the workload high. The subframe spacer/bush things are a big job, but having said that if you just drop the subframe down on the bolts I suppose it isn't so bad. I took my subframe completely off and had it seam welded and powder coated in which case all the suspension has to come off.A man of your means should have it done in a couple of hours tops. What are these "solid steering rack bushes
is it something I can add to the already crowded suspension setup on my car?
if it can be fitted and there is a .00000.001 % gain then I neeeeeeeeeeeeed them
Like these...
http://www.gotuning.com/product_info...oducts_id=1281
http://www.tegiwaimports.com/tegiwa-...da-s2000-3034/
Yeah, the subframe ones look a bit of a faff and it'll need a geo afterwards so I'm mulling over a trip down to get Dixon to do the lot. It's getting cold on my drive
Thanks Gary, although the Blue Ones do it for me, I'm just about to order half a dozen Oem oil filters of Si, I may ask him to price me some Spoon ones up.i feel that I might aswell get shot for a sheep as for a Lamb
I suspect my car will be noisy,crude, and uncomfortable,so I may just as well put all the bits on it to make it more so
Only choking
it will be like a pussy cat with lovely comfortable suspension, but possibly I little bit of a noise from the dog cut gears, apart from that it will ride like standard.
Only choking
Like these...
