Speaker Interference
Old Jun 20, 2008 | 09:11 AM
Ultra_Nexus's Avatar
Default Speaker Interference
Right, I have gone through an completely upgraded the stereo system within the car.
Amp is in the boot and speakers have had new thicker wire fitted through. Yes, that was a b4stard to do!
Anyway, finally fitted my amp today, and turned on.
Great - nice and loud
So I went for a test drive.
Whining
Not loud, but enough to be annoyed with. Also get pulses of clicking on tickover.
Now, am I needing a cap or is a simpler solution of a ferrite ring enough to remove this fly in the ointment?
TIA
Old Jun 20, 2008 | 09:59 AM
Boab01's Avatar
I had this problem with the FD2, most likely it's a bad earth OR the power cables for the amps have been run along the same bit as phono cables from the headunit to the amps.
Make sure your amp is earthed properly and even better if it's earthed to the same place the stereo is earthed to. Also ensure that your power cables run down one side of the car and the speaker cables on the other.
You could also plug in a ground loop isolator (10quid from halfords or less from ebay) but that didn't work much for me.
If it helps my Dad had the same problem with the Linn sound system in his Aston Martin
Old Jun 20, 2008 | 10:01 AM
Paper Lawyer's Avatar
Are the speaker wires down the sills and the amp power cable down the side of the tranmission tunnel? That should minimise interference.
Old Jun 20, 2008 | 10:16 AM
mikey k's Avatar
Ignition noise injection on to speaker cables or crossovers IMHO
Old Jun 20, 2008 | 10:17 AM
[QUOTE=Paper Lawyer,Jun 20 2008, 06:01 PM] Are the speaker wires down the sills and the amp power cable down the side of the tranmission tunnel?
Old Jun 20, 2008 | 10:21 AM
NeilB's Avatar
you earth should alwats be as short as possible to the car body.
Old Jun 20, 2008 | 10:25 AM
Yeah, it is short, but the wire is a bit thin and the contact probably a bit crap.
I still think that the power wire is the main concern, although I will try the nice beefed up earth first JIC as it is a hellofalot easier to do, especially with hayfever kicking my a55 at the mo!
Old Jun 20, 2008 | 10:33 AM
mikey k's Avatar
Sort the earth as well!
evan2
Sep 24, 2008 09:48 AM
OCMusicJunkie
Jul 9, 2007 08:45 AM
sleeze
Jan 10, 2007 05:40 AM
Ajjra
Feb 27, 2004 11:09 AM
dirt
Jun 26, 2001 02:44 AM
