Spindle Nut Query
Old Nov 27, 2007 | 05:48 AM
taffyb's Avatar
Thumbs up Spindle Nut Query
Hey all,
Well in line with some peoples predictions my sodding "wheel of fortune" ticking/creaking noise has come back !!!
History - had some issues (1 being noise), took to honda grantham for inspection, they checked everything, (bearings, brakes, cv joints, diff etc (i've been told)) couldnt find anything wrong, put it all back together = noise gone.
However, a week or so ago noise came back.
Only happens when car been driven a few miles, not under harsh braking only everyday pulling up to junction/stopping etc, happens whether clutch in/out, seems to be a rotational clunk/creak, doesnt seem to have affected the car & doesnt appear to happen on corners, when turning, accelerating etc.
From the extensive searching i've done on the forum (uk&us etc), some of the original advice from people like Aldfort etc & as honda couldnt identify any issues with anything else, kinda narrowed it down to Spindle nut issue.
I've found the TSB for it & the process for how to do it.
However my questions are:
1) Do you think i am right in thinking spindle nut.
2) Would it need replacing or can existing one be used? (not sure what honda did)
3) After paying honda for inspection & it not being fixed i have any grounds to get it done for free / discounted etc?
4) Has anyone had to pay honda to this in the past? If so roughly how much?
Cheers all
Brent
Old Nov 27, 2007 | 06:07 AM
lower's Avatar
Is it a single creak/click each time or a series of creaks/clicks every time you pull up to a junction?
Old Nov 27, 2007 | 06:15 AM
taffyb's Avatar
its like a "wheel of fortune" when the pointer hits a pin. Almost or clunk/creak noise is the best way to describe it. Not a distinct bang or scrape.
It sounds 1 per rotation, but obviously cant be sure. That keeps going until the car stops.
Cant hear it when driving but if braking for junction/to stop/pull up etc, the with normal braking can here it when get about 25 ish mph down to stop. Cant hear if brake very gently or hard.
The reason i say it may be spindle, is it was good when first had it (just had new tyres) so may have been tight then & over time become loose. Honda took it off to check everything out so tight and good. Then again became loose over time again & now back.
Trying to find out if honda:
a) replaced the nut when inspected.
b) what torque value it was tightened to.
c) whether splines were greased where comes in contact with hub.
Old Nov 27, 2007 | 06:32 AM
lower's Avatar
I doubt they would have undone the hubnuts and retorqued them as the nuts should have been replaced.
That should be your first port of call to fix this problem. The hubs nuts are not expensive and its an easy job to do.
You could potentially reuse them if you did the job yourself, but for the cost of them i replaced mine.
Old Nov 27, 2007 | 06:36 AM
taffyb's Avatar
Well at this stage i'm not sure whether they did replace them & what they torque'd them to, trying to find out.
Yeah i agree first port of call, prob is i have literally no tools to do it myself, so may have to take it back to Honda.
Got quoted
Old Nov 27, 2007 | 06:43 AM
lower's Avatar
They don't need to slip the diff out
Once the hub/spindle nut is loose, the driveshaft should slide on its splines. One of mine was a bit rusty, but a good wallop with a soft face mallet free'd it up. The you could push grease in from both sides to get grease onto the splines.
I can't believe that your dealer would do it without fitting new nuts. The nuts are staked over to stop them coming loose and you have to deform part of the nut where it is stake to loosen them. One of mine split slightly where it had been staked when i levered it out of the groove.
Old Nov 27, 2007 | 07:18 AM
taffyb's Avatar
Well the mechanic i spoke to at Honda say he "may" have to, so in light of what you said, should be about
Old Nov 27, 2007 | 11:48 PM
taffyb's Avatar
Had a chat with Honda Grantham last night & they've agreed to do a free inspection on Saturday Morning & if i can prove that the TSB for this problem exists, then fingers crossed they'll replace the nuts, grease everything up & tighten to the correct torque setting.
Does anyone know a) where i can find the instruction & b) whether from experience Honda either do/dont like sorting this out?
Cheers
Brent
Old Nov 28, 2007 | 05:02 AM
lower's Avatar
Not the best version, but its just about legible
https://www.s2ki.com/forums/index.php?act=m...&img=80392&md=1
Old Nov 28, 2007 | 05:51 AM
taffyb's Avatar
cheers lower, you've been a great help
Just hope they dont kick up to much fuss now ???
