Squeaky brakes
:hello: Hi all
I changed my brake pads the other day and they were fine initially but now they're squeaking a ridiculous amount. I made sure I copper-greased the backs of the pads and between the shims but I wasn't sure how much grease to use. I only added a very thin layer. Might I have just under-greased them? Or can anyone tell me what else I should check for? Might giving them a clean help? Thanks. :) |
If you've copper greased them they should be ok. A thin layer is about right :thumbup:
My redstuff pads squeaked for a while after I first changed them. Run with it for a while before taking them off again. Andy :) |
Cheers :)
I'll try to put up with it and see what happens. |
I found that Mintex pads squeak sometimes. OEMs are fine.
Have you done a couple of emergency stops ?
My Pagids squeaked initially, but don't any more.
Mintex on the rear of my Primera. They squealed like anything for the first few weeks, then it went away.
I have mintex all round - never had a problem.
there are different types of Mintex Pads, i have Mintex Extreme on the Front they squeak after 3 / 4 month of wear.
