Standard Brake Discs
Old Oct 29, 2014 | 01:07 AM
reblle's Avatar
Default Standard Brake Discs
I'm keeping my car standard and I won't be doing track days in it but I want to change the discs,pads etc wheres the best place to go to? hav'nt tried Honda main dealer prices yet but I do want decent quality i.e parts that work but don't rust too quickly the present discs look crap.....been looking on here for a while can't seem to find the right post everyone seems to talk discs and pads for race days all advice welcome
Old Oct 29, 2014 | 01:24 AM
Ara1's Avatar
For normal day to day driving I find OEM pads and discs just fine. For parts try one of the retailers on here - Si @ Hendy or Tegiwa. Always found them both to be good on prices and excellant service.
As for rust. Is it just surface rust because of lack of use? If so this will go when on your next drive
Edit: where are you based? I'm sur eothers can recommend someone local for fitting
Tegiwa Imports's Avatar
Former Sponsor
Have a look at Stoptech
Front
http://www.tegiwaimports.com/stoptec...nda-s2000.html
Rear
Old Oct 29, 2014 | 01:35 AM
lovegroova's Avatar
Have you tried reading the "Forum Favourites" sticky?
https://www.s2ki.com/...brakes-tct-etc/
As well as Si at Hendy, have a look at Cox Motor Parts: http://www.coxmotorparts.co.uk/genui...009-p-630.html
It seems the Honda dealers are cheaper than Tegiwa for discs and pads
Old Oct 29, 2014 | 01:42 AM
Ghost-Reaper's Avatar
Oem discs are fine for the road and ok for the track to be fair. Oem pads are also good for the road, the oem stuff is what's Honda designed for road use.
The stoptechs tegiwa suggested are also very good, I use them on mine (some track use).
Brake discs will get surface rust on the swept surface as its bare metal that's exposed to the elements. If you want to keep the rest tidier paint the centre area and the outer edge with high temperature paint.
sound_wave's Avatar
Mtec for brake discs and ebc yellows for pads. Job done!!
Old Oct 29, 2014 | 01:54 AM
richmc's Avatar
Why is it whenever somone asks about stock brakes, all that comes back is the mega expensive exotic stuff, drilled, grooved coated etc.
As you asked about STOCK BRAKES, then your local motor factor should be able to supply for around £30 - £40 a cormer, Honda pads are just fine and at last look a resonable price as are OEM type replacements like Padget etc.
For road use you don't need anything else, and some argue they are fine for light track as well, for info brake fluid is stock DOT4.
Old Oct 29, 2014 | 05:21 AM
tangoray's Avatar
Because Sportscar
but seriously when you weigh up prices. MTEC grooved/drilled/dimpled protective coated discs all round come in at £37.5 per corner....that's pretty hard to beat
Old Oct 29, 2014 | 02:26 PM
Booti's Avatar
Have a look at Brakes International for OEM quality parts
Old Oct 30, 2014 | 01:02 AM
richmc's Avatar
Originally Posted by tangoray
Because Sportscar
.......grooved/drilled/dimpled............
That's when brake disks become break discs
