Stereo help please
I have recently fitted a head unit with USB and aux in so I can connect my Ipod to it. At the point of fitting I could only get the basic harnesses so lost the use of the dash control whilst I could source the necessary parts.
I went to connect the parts today in order to restore the dash controls and they appear to be the wrong ones. As such I reconnected the stereo how I had it before and nothing happens. No power to the stereo at all.
So in one swift move I have gone from no dash controls to no stereo at all. I am trying to figure out what can have gone wrong in order to locate and swap out as necessary so any help from people who actually know about this stuff would be greatly appreciated!
Are there any obvious things I should check for first of all or is this just a case of take it to someone who knows what they are doing?
Thanks,
Ross
Thanks,
Ross
Originally Posted by unclefester,Mar 30 2010, 09:49 AM
You need to check two fuses, one on the radio circuit and the other in the Auxiliary power circuit.
What model of radio did you try and fit and where did you try and poke the wires?
It is a Kenwood KDC-W4544U. Only a cheapy with aux connections on the front. I haven't jammed any wires anywhere with the exception of all the usual wiring in the recess behind the stereo itself.
Thanks
I managed to blow the Aux fuse by stuffing wiring for the alpine to the right of the dash aperture - the radio needs both the radio fuse and the aux fuse to work. Have you checked to see if you have power to the Aux socket?
Yes, the aerial is definitely back in. Just double checked.
I think I am displaying the true meaning of little knowledge being a dangerous thing.
Originally Posted by unclefester,Mar 30 2010, 10:44 AM
The auxiliary socket is the fag lighter type socket between the rear seats just below the central glovebox
Do NOT go sticking stuff in the fusebox!
Just tried the spare fuse with no luck. Still no power to the stereo.
Fella - I just checked the user guide 4 you.
there's a 10amp fuse at the back of that puppy.
http://www.kenwood-electronics.co.uk/WebFi...544U_W4044U.pdf
I wager money that's your prob mate
