Stereo installation
Whilst I am in no doubt that the OEM wires can handle the current, I am very much an advocate of using the right equipment for the job. I got the cables with my amp and saw no reason why I should not use them. Fortunately the missus was more adept at running the cables through to the doors than I was
Thicker cables also allow for expansion of the system should I deem necessary
There's a man that likes to do it properly, Loftust!
I'd avoid Honda like the plague personally and take it to audio specialists if you're going down that route. I'd pay for someone to fit the amp, as they'll do a tidy job, set it up properly and do the cabling properly which means you're unlikely to run into proplems in the future, like alternator whine, grounding issues etc. Paying Honda to do it all will be very expensive.
Doors are a piece of cake - especially if you buy the adapters - just a case of unscrewing the old ones and screwing in the news. I'm no audio specialist, but this is as easy as it comes.
Head unit is easy too. In fact, probably the easiest car i've ever fitted. Civic EP3 was the worst.
Having just changed my HU, my best piece of advice is once you have the bottom loose, use a flat screwdriver with some cloth around it to prevent scratching/damage and use it as a lever in the top parts of the trim, mine came out a treat after that.
