strut brace info ?
You won't notice a difference with the front one unless you get the lower one fitted too.
Not sure about the rear. The lower one makes a difference, but I have no experience with the upper one.
The upper front does make a difference, hard to comment if you havent even fitted one
I know sneakish had one fitted then took it off then flet the difference, it may not be as obvious as on other cars but the front upper has a part to play. the other comments are correct, both the front lower and rear lower are a vast improvement on feel, most popular choices are spoon or cusco.
Originally Posted by GrittyShaker,Feb 17 2009, 03:28 PM
I have fitted a front upper one and did not notice a difference. (
)Then a couple of days later I fitted the lower one and noticed a vast improvement.
)Then a couple of days later I fitted the lower one and noticed a vast improvement.Where did you at what circumstances did you notice a difference?
Originally Posted by Ajs_s2k,Feb 17 2009, 02:34 PM
Was this a rear lower Scott, i have 2 mods to fit to my car then shes finished the last mod was going to be a lower rear brace.
The car feels much sturdier and more predictable when caning it through the twisties. You feel more in control, because flexing is reduced, IMO.
