TCT :(
Old Jul 17, 2013 | 01:15 AM
Squeak's Avatar
Default TCT :(
I have the tct rattle!
Does anyone have access to sandblasting that would be kind enough to do it for me? For some sort if reward if course
If not where are people buying a tct from these days?
Old Jul 17, 2013 | 01:22 AM
User 4225's Avatar
It's not imperative that you get it sand blasted, as long as you "rough up" the contact face of the worm gear it's not crucial how you do it. A lot of people have used emery cloth/sandpaper to achieve the same result, sandblasting is just a bit quicker.
If you're happy to tackle it yourself, i'd get it to bits in the shed and get the sandpaper out! Just be sure to rinse it through with some petrol or something prior to re-assembling
Old Jul 17, 2013 | 01:45 AM
S2000_FUN's Avatar
That's an alternative solution if you can't have access to sandblasting
http://www.youtube.com/watch?v=DpyyZ...ature=youtu.be
Old Jul 17, 2013 | 03:42 AM
j8mie's Avatar
Cheers for posting that video
Makes the job look rather easy.
Old Jul 17, 2013 | 04:02 AM
User 4225's Avatar
It's one of those jobs that sounds a lot worse than it actually is!
Old Jul 17, 2013 | 05:00 AM
SuperHamz's Avatar
Really good video, bookmarked so I don't panic when I hear it go.
Old Jul 17, 2013 | 05:18 AM
BenRNBP's Avatar
Did the same earlier - bookmarked and noted
Old Jul 17, 2013 | 06:38 AM
caseh's Avatar
If the above fails:
Old Jul 17, 2013 | 11:52 PM
S2000_FUN's Avatar
Cheers guys I also thought it will be very helpful as a cheap solution. Of course if somebody wants a permanent solution I would go for the inline pro TCT. I used to change TCT's every 2000 miles when I became FI. I installed the inline pro tct and never looked back
Old Jul 18, 2013 | 01:07 AM
Squeak's Avatar
Where can I get an inline pro TCT from?
Found them Not sure I need race spec but if it means it will never fail again??
