Technical FAQ
Here's the UK forum's tech faq. It is a joint effort by many of the UK owners and covers a lot of the questions which are asked on a regular basis, plus a number of very important technical issues which you will probably be unaware of (especially since most of the UK Honda dealers are also unaware of them
If you are considering buying an S2000 (or you have just become a new owner) I recommend that you read through these FAQs, as you are bound to learn something new and important - I know I did, when I compiled them
Running in your new S2000!
The running in period for the S2000 is 1000km before the use of VTEC. This means 650 miles before you rev over 6000rpm. It is then recommended that you go up by 1000rpm for every 100 miles. Running in, isn't just the engine so it's important to vary rpms as much as possible and change gears as often as possible. You're bedding in the whole drivetrain/brakes/engine.
Oil usage can be quite high while the engine is running in, so check the oil with every tank of fuel.
Honda Recommended Owner Maintenance
The following is taken from the owners manual
With every tank of fuel
Check engine oil level
)If you are considering buying an S2000 (or you have just become a new owner) I recommend that you read through these FAQs, as you are bound to learn something new and important - I know I did, when I compiled them
Pardon my ignorance, but what difference does the removal of the air box cover make performance-wise, is it noticeable? (apart from the inferred increase in noise?) Wouldn't it allow more foreign objects into the engine?
Removal of the airbox lid gives a lot more noise, accompanied by a slight loss in performance. It's a trade off that a lot of people willingly make. The air intake on the S is badly located over the radiator, and suffers from heat soak problems due to build up of engine heat under the bonnet, particularly when the car is stationary in traffic. Removing the airbox lid just allows a greater volume of the hot air to enter the filter.
As for stones and other objects getting into the filter box with the lid off, I can't take the risk very seriously when you consider the path such an object would have to follow to get into the box.
The sound is awesome with the lid off, but a little rough and agricultural for my tastes. Give it a shot... see what you think!
Originally posted by Chris Type R
Hi Neil
How about adding a paragraph about not using the spare saver on the rear because of LSD damage, and only using a flatbed if broken down ?
CTR
Hi Neil
CTR
There is also the product reviews section which is quite new. Looks like it could be great when people start really using it
https://www.s2ki.com/reviews/index.php
