Too low?
Old Aug 9, 2014 | 09:49 AM
Scottland's Avatar
Default Too low?
Hi,
Fitted coilover a couple of weeks back and have been running it this height with no issues or strange noises (other than my polybushes creaking).
I was planning on taking the rear up 10mm and 5mm at the front when I fit 17s in the next few weeks but keen to listen to some other peoples opinions on the ride height - both aesthetically and technically.
Old Aug 9, 2014 | 11:05 AM
Nottm_S2's Avatar
It looks pretty low but if you're not hitting stuff, its not a scatty deathtrap on bumpy roads and your back isnt currently feeling like its made of wood then its all good
Lookswise its great imo
Old Aug 9, 2014 | 12:50 PM
rhauri's Avatar
Pic isn't working dude, keen to see how it's looking!
Old Aug 9, 2014 | 01:07 PM
Scottland's Avatar
Dropbox have changed their linking system, I've edited it now, should work.
Old Aug 9, 2014 | 01:13 PM
Scottland's Avatar
The ride feels pretty good to be honest its firm but not crashy at all, better than our 500 by miles. I'm just concerned with compromising geo adjustments or needing driveshaft spacers - I was under the impression I would get vibrations etc if this was an issue.
Old Aug 9, 2014 | 01:31 PM
rhauri's Avatar
Looks great mate!! May wanna raise for bigger wheels, but overall radius is very similar.
I'd fit and see - raise if required / desired
Old Aug 9, 2014 | 01:43 PM
Tim S's Avatar
If it doesn't vibrate at speed it doesn't need driveshaft spacers. They're only to move the contact patch of the driveshaft pegs in the cups if the lands are worn, nothing to do with geo.
I'd be surprised if you can get the geo in spec that low on standard rear toe arms. You will also have rear bump steer but if you're not noticing it it isn't worth worrying about.
I presume there are no speed bumps or multi storey car parks where you normally drive then! Mine was that low at one point and I grounded on both. I had the car raised 10mm and it still scrapes on multi storeys.
Old Aug 9, 2014 | 03:10 PM
AlexGJ248's Avatar
Looks good Scott.
Old Aug 9, 2014 | 11:18 PM
lovegroova's Avatar
Your idea of more rake is a good one, and yes it's a bit too low.
Old Aug 10, 2014 | 01:35 AM
Scottland's Avatar
Thanks for the replies chaps
Thanks, yeah I know the spacers were just to move the contact area in the driveshaft cup - just confirming it was vibration was the main symptom.
Not sure weather to go for adjustable toe arms or not anyway, but having it so low that it compromises I can get geo in spec is not what I'm after.
I've never really wanted it really low - all the wheels have to come off when I swap them over anyway so will be waiting until then to raise it. Maybe I'll end up raising it more than 10mm/5mm
