Tow hitch / bar?
Old Jan 16, 2011 | 01:03 PM
Robertio's Avatar
Default Tow hitch / bar?
Before I have to order one from the US is there anywhere in the UK that supplies a towbar for an S2000?
Don't worry, it is just for mountain bikes/snowboards, I don't plan to stick a trailer on and try to drag the race car around
Old Jan 16, 2011 | 01:09 PM
Dan Hale's Avatar
I'm sure he'll reply here, but if not, PM Aquilaeagle as he's put one on his beater S.
Old Jan 16, 2011 | 01:24 PM
AquilaEagle's Avatar
Administrator
No.
I got mine from the US (AFAIK I am the only person with one in the UK)
You may need to change the ball on the end though, although I get away with mine
I do use a trailer, tyre trailer. I CBA now, but you could search and find my posts about it
Old Jan 16, 2011 | 01:33 PM
Robertio's Avatar
Thanks I did find your posts when I searched earlier, was just ever optimistic someone may have got one locally - I take badly to paying VAT on import duty and shipping so try to avoid it whenever possible.
Looking at the pictures it wouldn't be hard to make one, but don't have the free time at present, so I'll see how expensive shipping is going to be.
Old Jan 16, 2011 | 01:38 PM
Administrator
Chase Race are probably the guys to get one from these days.
Old Jan 16, 2011 | 01:42 PM
euan's Avatar
Ian, I always meant to ask you, do you have problems with ground clearance with yours ie if you have to go up a steep ramp?
Old Jan 16, 2011 | 01:45 PM
Administrator
None whatsoever
I think the Cat sits lower than the tow bar
Old Jan 16, 2011 | 03:54 PM
Petron's Avatar
IIRC wasn't there a post somwhere with a vid of an S2000 towing a caravan? May not have been in the UK though
Old Jan 16, 2011 | 11:07 PM
Dan Hale's Avatar
There was a guy in the states using his to tow a boat IIRC.
Old Jan 17, 2011 | 11:44 AM
CHIPPO's Avatar
Yankee tow balls are 2 inch and UK/Eurpean 50mm, don't know if Uk/European spec hitchs will fit the 2 inch ball , but if you have a Yankee hitch and a 50mm ball you can loose the trailer. My mate had a Yankee ski boat and trailer, he had to get a 2 inch ball or risk the boat and trailer
Its approx 0.8mm differant
