TTS Rotrex AIrbox
Old Aug 27, 2011 | 11:37 PM
david.mt's Avatar
Default TTS Rotrex AIrbox
Has anyone fitted or made an airbox for their TTS Rotrex setup. The filter is just open and I want to see if fitting an airbox will have any effect before I try more radical cooling changes.
The CT system comes with a CF airbox and I am sure the Rotrex can be made to fit. Has anyone tried this or done something different or should I just get on and see what can be done .
Photos as usual please.
Old Aug 28, 2011 | 01:51 AM
bgh187's Avatar
What about running a pipe down to where the aem has its filter.
I don't know if this is do'able, just putting it out there
Old Aug 28, 2011 | 02:51 AM
oxhouser's Avatar
I had mine shrouded from engine and rad
https://www.s2ki.com/s2000/gallery/i...1-img-0291jpg/
Old Aug 28, 2011 | 03:17 AM
razzele's Avatar
Oxhouser your pic isnt working
Im toying with boxing it and then making a vent in the wing and guiding air in that way, a bit extreme though.
Old Aug 28, 2011 | 03:44 AM
s2konroids's Avatar
I'd change the weedy standard filter for something bigger and just add an air feed or cooling plate.
Old Aug 28, 2011 | 08:36 AM
oxhouser's Avatar
[quote name='razzele' timestamp='1314530229' post='20921042']
It's working when I view it
I changed to an ITG filter about twice the size on ITG recommendations , shrouded the back with an aluminium sheet that had a rubber seal on top to seal against the bonnet when shut, another plate ran in front of rad and under the filter, not 100% closed but it did the job. I would not bother with wing vent unless it's something you want for looks as well, a hole in the rad plate and the bulb access hole usually flow enough
Old Aug 30, 2011 | 09:58 PM
eSeM's Avatar
A long time ago I cut out the faux vents ..... I have have used one of these to to pipe cold air onto the intake filter. It is a bit of a bodge job at the moment but if I ever get the time I will do it properly.
The airbox is a waste of time IMO, if anything it will restrict the airflow.
Old Aug 30, 2011 | 10:52 PM
bgh187's Avatar
What about using a K&N Apollo air filter. It's completely shielded and has a front attachment for a cold air feed.
HKS also make an almost identical enclosed filter.
Old Aug 31, 2011 | 12:16 AM
richmc's Avatar
Thats low, I'd be worred about water getting in.
Old Aug 31, 2011 | 01:02 AM
eSeM's Avatar
Nah! all I am doing is piping the air from he vent into the vicinity of the air filter.
