Tuning
Old Aug 13, 2008 | 01:00 PM
Debeneezer's Avatar
Default Tuning
Looked through the FAQ's but couldn't see an answer to this question.
We have had the car for about a year now, and it may be my imagination, but when it gets to 6000 revs it no longer seems to give that little 'kick' it used to.
Does this mean the car might need tuning? If not, what might the problem be?
We have just had a Honda service done which we had hoped would address the problem, but it doesn't seem to have made any difference (except the car needed a wash, the oil looked cleaner, and our bank balance is emptier).
Old Aug 13, 2008 | 01:05 PM
eSeM's Avatar
If you take the ECU out of the car and put it into the freezer for half an hour it fixes this problem.
You are just getting used to it.
MB's Avatar
MB
Member
You can't really "tune" modern cars.
Assuming it's been serivced well and has good oil and also new air filter it should be ok on the whole.
Warm weather doesn't help.
I like to do an ECU reset on a regular basis. Keeps it on its toes.
Try that and you should notice it being more spritely for a while!
It also might be fine, and just your imagination - in which case a dyno run can often help - shows what power the car is putting out. Just pick a decent one!
Old Aug 13, 2008 | 01:12 PM
Debeneezer's Avatar
Sorry to be a non-techie, but can I do an ECU reset, is that what eSeM was saying in the above post?
What is a dyno run?
Should I get a friendly mechanic involved?
Old Aug 13, 2008 | 01:15 PM
MB's Avatar
MB
Member
See here, a few lines down...
https://www.s2ki.com/forums/index.ph...&f=25&t=467545
Or you can disconnect the battery for 20 mins but pulling the fuse is easier.
No mechanic needed!
Also worth just going out and giving it living hell for a while, just to sharpen it up!
Old Aug 13, 2008 | 01:17 PM
eSeM's Avatar
Originally Posted by Debeneezer,Aug 13 2008, 09:12 PM
What is a dyno run?
Important if you make serious modifications to your car ...... willy waving for everyone else.
Old Aug 13, 2008 | 01:25 PM
Debeneezer's Avatar
No mechanic needed!
Thanks for that, I will look again tomorrow when I'm a bit more sober, as it looks a bit complex tonight.
Sure it will be simple when I can look at the engine in daylight.
Thanks for that, but not my scene as I am a woman
Old Aug 13, 2008 | 01:30 PM
MB's Avatar
MB
Member
Also very useful for diagnosing problems
Old Aug 14, 2008 | 02:20 AM
Debeneezer's Avatar
Having just read the info in the link, I get the feeling we may be too gentle with the car, even though we thought we were giving it hell from time to time. Could this be the case?
Hubby is going to pull the fuse shortly, so will give update later
Old Aug 14, 2008 | 02:37 AM
MB's Avatar
MB
Member
It's designed to be abused all the time - as long as its warmed up and service correctly
I used to drive mine as fast as the roads would allow pretty much all the time.
