Turn in
As per title. I noticed recently that the turn in on my S seems a little less accurate. It seems to be more understeery (if such a word exists) I had the alignment done a month or so ago. I wondered if my tyre pressures could be wrong (34psi) and if that would make a difference.
If the pressures and geometry are correct then the front tyres will wear the inside edges first. I pushed my S2000 pretty hard on turn in and corners and as a result I had near bald inside edges yet the centre and outside (visible parts) looks perfectly good!
The tyre should roll onto the outer edge whilst cornering. the inner wheel is unloaded.
Inner edge wear may be too many straights & not enough bends.
Dan,
If your car feels more understeery since the geo, what have they done to it? Too much toe-in either end, too much Front castor, way too much camber even?Settings please, Carol.
The weather's been colder last couple of weeks: your post is unclear as to whether the understeer problem actually occurred since then or the spannering.
Wear on the front inside edges is very well hidden and make a huge impact.
