under powered?
Old Jul 6, 2008 | 07:23 AM
nashby's Avatar
Default under powered?
my 2000 s has 43,000 miles on clock, it is very well looked after but when i really go for it, it seems to struggle going past about 110mph, now i know its not the done thing but going on its book speed i would say its not running right or something
Old Jul 6, 2008 | 07:28 AM
Ultra_Nexus's Avatar
Well, 110 is pretty fast I suppose and air resistance with the top down is crap.
Air resistance is also the square of velocity
Try holding them gears as long as possible to get the maximium from your engine.
110 is still 4th gear!
Old Jul 6, 2008 | 07:33 AM
nashby's Avatar
agreed but after 100 or so it doesn't seem to pull, not matter if its bouncing off the limiter or lower gear, roof up or down still the same
Old Jul 6, 2008 | 07:36 AM
AquilaEagle's Avatar
Administrator
Is it a Japanese Import?
Old Jul 6, 2008 | 07:38 AM
You thinking of poor fuel?
Speed limiter had no effect on my acceleration upto it.
nashby's Avatar
No uk car
Old Jul 6, 2008 | 07:40 AM
nashby's Avatar
i did adjust the valves the other day which helped a bit, found the inlets to loose and the exhausts to tight
Old Jul 6, 2008 | 08:21 AM
SideWaysOnFire's Avatar
Import would have limiter.....
Old Jul 6, 2008 | 08:24 AM
nashby's Avatar
its not a limiter its an underpowered issue
Old Jul 6, 2008 | 09:05 AM
aaroncosbey's Avatar
What fuel do you use?
