Understanding suspension
Old Jul 24, 2011 | 12:21 PM
m1bjr's Avatar
Originally Posted by Kobe
isn't it just suspension travel adjustment..?
the spring stiffness won't change,
as nexus says, if you lower the car then you are not allowing the suspension to work as much.. but then that depends on what sort and size of bumps you intend to drive over..
+1
It's so you can corner weight the car
If you jack up one corner, that corner takes more of the weight.
Think of a four leg table, and where the weight goes when you slip a beer mat under one of them
'Preload' is a bit misleading really - often seen on the Tein stuff too.
The KW3 and many others (TUV approved normally) have helper springs.
These small springs are always totally coil-bound with the car sat still on the level.
But get some air and they keep a little tension on the damper piston so the big springs dont fall out.
A better but more expensive solution to the same ends.
I think this is what Dembo is thinking of?
Old Jul 24, 2011 | 12:34 PM
Dembo's Avatar
Errr, no. I was talking about preload. Watch the video. If you had preload, you wouldn't need the helper springs. Corner weighting comes from adjusting the ride height, not the preload. Maybe the confusion comes because on coilovers without independent preload adjustment (like my Bilsteins) raising the ride height increases the preload, but it's not adjusting the preload that allows you to corner weight, it's adjusting the ride height, and you get the preload change whether you want it or not.
Note that the video suggests using no preload, and the fact Bilsteins, KWs and the like have helper springs suggests they're also intended to be used with no preload.
Ramzyj
Sep 7, 2011 06:09 PM
POG
Apr 15, 2011 11:17 AM
s2konroids
Oct 3, 2008 11:30 PM
gazs2kjdm
Sep 21, 2008 02:21 PM
Espionage01
Feb 9, 2006 09:08 PM
