Usefull Products
Old Mar 6, 2008 | 01:37 PM
doyler's Avatar
Default Usefull Products
When trying to remove my brake discs today,i came into a spot of bother when trying to remove one of the countersink bolts that holds it place.I had tried to crack it a few times with my impact driver and it wasnt budging,i was starting to get hesitant about either ruining my bit or destroying the bolt.Got this stuff from work,its called ''freeze off'' and its made by an irish company called ''Tomac''.Just spray it on for a few seconds,wait about 2 minutes and life should be a lot easier for ya.It works by contracting the metal hence breaking the bond from corrosion or rust etc. I have used this on many applications in work and found it very easy and effective,a much better alternative to heat.Very important to use gloves tho,this stuff can give you frostbite
Is there a thread where members can discuss usefull product or tools they have come across?i think it would be a good idea
Old Mar 6, 2008 | 01:55 PM
euan's Avatar
I tried something similar on my bike for removing some stubborn bolts - it didn't seem to be any more effective than Plusgas and good old WD40 IMHO.
Old Mar 6, 2008 | 02:20 PM
doyler's Avatar
On a nut and bolt assembly wd 40 is fine,where some of the thread is exposed,but where a bolt is in a component or car part for example it cant always penetrate down through the threads,I had a bushing bolt stuck in my old civic,used wd 40 to no avail.Still stuck.Used the freeze off,put on spanner and cracked it with a hammer,wholla!! Are hondas prone to having suspension bolts seize?? i know a few people who had to get their lower control arms replaced due to seized bolts?
Old Mar 6, 2008 | 02:47 PM
RISLAR's Avatar
Yep the S in particular is really bad!! i think i'll try that freeze off, it sounds good do you know who stock this?
Old Mar 6, 2008 | 11:06 PM
doyler's Avatar
I dont know anyone who stock this unfortunatly or if your able to buy it off the shelf as iv never seen any of their products in a motorfacter or hardware store etc.......One of their sales reps comes round to the company i work for every month and tops up our stock.They do all sorts of products like copper grease,threadlock,adhesives and so on..
But the companys name is Tomac Products Ltd.
Tomacproducts@eircom.net
00 353 51 396964
Old Mar 7, 2008 | 12:27 AM
j8mie's Avatar
Must admit I have some Plus Gas and am very impressed.
Old Mar 7, 2008 | 02:56 AM
RISLAR's Avatar
00 353 51 396964
Thanks fella, i will give it a go, i'm always open to suggestions and new products
Old Mar 7, 2008 | 03:05 AM
Nick Graves's Avatar
I've recently read about a similar product that's commercially available.
Cannot remember where though!
Old Mar 7, 2008 | 03:22 AM
lovegroova's Avatar
Would it be a good idea to let Chris Franklin know about this stuff? I guess it might help him?
Old Mar 7, 2008 | 03:30 AM
Si2k's Avatar
I'd be wary of it making metal more brittle though. Could cause problems
boxmetogo
Jan 19, 2011 08:26 PM
andy2000
Dec 24, 2010 03:38 AM
nomadicS2k
Jun 4, 2008 01:17 AM
bikemechanic
Jan 27, 2008 12:56 PM
