Wee bit of a problem - left sidelight
Old Aug 20, 2014 | 07:56 AM
Forza Minardi's Avatar
Default Wee bit of a problem - left sidelight
Hi, I've had a wee problem crop up with my S2000 - the front left sidelight no longer illuminates. I tend to jump to the worst possible scenario, so am imaginging the cost of a complete headlight unit replacement (seems to be £700ish?!), but you might have some suggestions that are more simple and less expensive? I've not had a chance to poke about in there yet, so to speak, how easy is changing bulbs etc.? I am having a service done tomorrow so might ask the guys to have a wee look.
Thanks in advance.
Old Aug 20, 2014 | 08:02 AM
kw_21's Avatar
Surely the first thing to check is the bulb?
Old Aug 20, 2014 | 08:20 AM
Dembo's Avatar
I'm afraid you'll need a whole new car. Can't be saved.
Either that or it's the bulb.
Old Aug 20, 2014 | 08:21 AM
Nick Graves's Avatar
SCRAP IT.
Old Aug 20, 2014 | 10:58 AM
mikefifth's Avatar
At the above
Check
Bulbs
Wiring
Ballast
Dont buy new unit. Go second hand
Old Aug 20, 2014 | 11:16 AM
unclefester's Avatar
Originally Posted by mikefifth
At the above
Check
Bulbs
Wiring
Ballast
Ballast ... for a sidelight?
Bulb / connnector - that's it. There are no contacts for that on the light unit!!
Old Aug 20, 2014 | 11:21 AM
I just use readymix for mine.
Old Aug 20, 2014 | 12:03 PM
mikefifth's Avatar
Originally Posted by unclefester
Originally Posted by mikefifth' timestamp='1408561129' post='23294984
At the above
Check
Bulbs
Wiring
Ballast
Oops I though he ment the actual light!
teach me to read
Old Aug 20, 2014 | 12:45 PM
richmc's Avatar
As changing the bulb etc. requires taking the arch liner off, I'd go with your plan "A", get them to sort it at the service, they will have the wheel off at some point at it will be a whole lot easier for them to do it.
Don't bother checking the fuse as it supplies all four sidelights.
Old Aug 20, 2014 | 01:00 PM
BenRNBP's Avatar
Opportunity to upgrade to Cree LEDs I think
