Weird tech issue
Old Oct 26, 2014 | 02:25 PM
Fatbloke's Avatar
Default Weird tech issue
This has been bugging me for a while. One of my rear wheels appears to protrude further than the other. Using very crude measuring methods, i'd say about 4-5mm.
I had put it down to the effect of a bit of camber (WiM fast road set up, not stanced nonsense) and one side sitting a little lower than the other, but I've corrected that now on the coil over adjustment and the difference is still there.
The geo has been done several times since I first noticed it, but everything is fine suspension and geometry wise and there's no sign of crash damage (I've had the car since 2008 when it had only done 13k, so it's not like it could have too much of a shady past) and it drives perfectly.
I only really noticed the difference between the two sides a while after I had spacers fitted, but presumably, everything must be back together properly as something would have been flagged up during geo sessions or services, or a hub and wheel would have fallen off.
Anyone got any idea what it might be? Can subframes be out of alignment?
Cheers,
FB
Old Oct 26, 2014 | 02:49 PM
Kitesurfer s2000's Avatar
maybe you should get out of the car next time ian when you have the alignment done hahahahaha
Old Oct 26, 2014 | 02:59 PM
Fatbloke's Avatar
Yeah yeah yeah, smart ass.
Done anymore ditch finding recently, Lee?
Old Oct 26, 2014 | 03:09 PM
if you give it out ian you should be able to take it.
Old Oct 26, 2014 | 03:11 PM
Have you checked to see if the tires are the same size?
Old Oct 26, 2014 | 03:13 PM
Or maybe one tire is inflated less than the other could be a possibility?
Old Oct 26, 2014 | 03:31 PM
noodels's Avatar
No cars are symmetrical <even Honda > and have a +/- tolerance corner to corner
Old Oct 26, 2014 | 03:48 PM
Fatbloke's Avatar
Everything is spot on, Lee (and do you think I would have chosen this handle is I couldn't take a bit of ribbing)???
Noodles, appreciate there's a manufacturing tolerance and I'm happy if that's all it is. Was just curious to know if it could be anything out of alignment........
Old Oct 26, 2014 | 05:03 PM
noodels's Avatar
The S2000 is hand built,some measurements if you want to check, or maybe not
http://beyond6000.blogspot.co.uk/
Old Oct 26, 2014 | 10:54 PM
Nottm_S2's Avatar
Mine had this when i spun and hit the kurb
More than 5mm though.
Had a new subframe
Pics?
