What is this box
Old Jun 14, 2015 | 03:58 AM
Mike's's Avatar
Default What is this box
Just about to install an apexi vafc2 and when un bolting the ecu i noticed this under the carpet and i dont know what it is
Old Jun 14, 2015 | 03:59 AM
Mike's's Avatar
It would help if i knew how to post pics from my phone !!!
Old Jun 14, 2015 | 04:10 AM
Mike's's Avatar
http://i845.photobucket.com/albums/a...psksidwyob.jpg
Old Jun 14, 2015 | 06:40 AM
ikaros_s2K's Avatar
If it's a japanese spec, it might be a speed limiter remover
Old Jun 14, 2015 | 07:47 AM
Mike's's Avatar
Uk spec 2003 im still confused
Old Jun 14, 2015 | 08:42 AM
AquilaEagle's Avatar
Administrator
Where does the wire from it go?
Old Jun 14, 2015 | 12:48 PM
User 4225's Avatar
Whatever it is, it's definitely aftermarket. Looks like it's a controller for something. anything written on it or stamped in it?
Old Jun 14, 2015 | 11:01 PM
BenRNBP's Avatar
Movement sensor for an aftermarket alarm ?
Old Jun 15, 2015 | 12:14 AM
richmc's Avatar
If it has "Pandora" written in it leave well alone!
Seriously you need to trace where the wires go to have any idea, check the colours if you can and see if you can find the same pair looking out of place around the loom somewhere, and see what connector they go into.
Possible candidates,
part of an after market alarm
speedo adjuster for an aftermarket diff
not a JDM limiter remover or KPH to MPH box (as said above)
Transmitter for a tracker
Until you know where it goes you (and us) can only guess.
Old Jun 15, 2015 | 12:19 AM
Mike's's Avatar
Nothing written on it at all just aluminium casing with sealed ends with 2 wires comming out of it and connected straight to the ecu loom, i will get some better pictures tonight and find out which wires its tapped into
