Wheel Bearinqgs
Well , one or both my rear wheel bearings are noisy , so the question is has any one managed to drift them out of the hubs or is it definelty a case of press them out ,
Getting the new ones back should be ok , bearing in freezer and hub housing in the oven ! We will see
Chances are the noise in the end. Is something else anyway , but on axle stands it certainly sounded like the wheel bearings even though they felt ok.
I did both of my rear bearings recently and they were tight, I think you will struggle without a press to be honest... If you lived near me I would lend you the use of my press... Keep the old bearing to press the new one in with, but I'm sure you know that
Will most likely get Toby to take them to work to do I am sure with Cook and freeze they will fit ok , will get hub assemblies off first, then see what happens.
Thanks for the offer Carbon as you say a bit far !
Fatty I worry about you !
No worries chip, your the one that inspired me to do my restoration so the loan of a press is no bother, it's been one of the best experiances and makes you realise you can do more than you realise if you give it a go.
It's ok I can get Toby to do it at work or i can get a suppliers arm up his back!
I was wondering it any one has got one apart with a large drift and moderate persuader. That's all
ntc432
Dec 4, 2007 05:59 PM
