Wheel Bearing Question
Hello everyone
Just a quick question, I have a squeak/squeal coming from my rear wheel hub. I think it's emanating from the wheel bearing
I was wondering if it's possible to re-grease them? I've changed wheel bearings before and seem to remember that they can be greased at installation but removal to re-grease is not possible. It started at Bedford (29th April) and I'm sure it's not the breaks (I changed the rear disks and pads last weekend).
If I need to get a new bearing fitted at the stealers does anyone know how much that will cost?
I was wondering if it's possible to re-grease them? I've changed wheel bearings before and seem to remember that they can be greased at installation but removal to re-grease is not possible. It started at Bedford (29th April) and I'm sure it's not the breaks (I changed the rear disks and pads last weekend).If I need to get a new bearing fitted at the stealers does anyone know how much that will cost?
Part No.s for Wheel Bearing & Rear Hub
OEM Wheel Bearing
SKU: OEM-44300-S47-008
Rear Hub
SKU: OEM-42210-S2A-000
Total cost
FunBox, did you get this done in the end? If so how much did the fitting cost?
Having been through the brakes thing, mine's at the dealers now and I'm pretty sure it's going to be the bearing.
i had a wheel baring go on mine, i fitte dit myself, cost me 55 notes which was cool from honda.
i did not have any squeaking, just had a loud runmble and clangin noise when slowing down, when i stopped several miles later the wheel u could hold the top and rock it to and throw. so hope its not that plus the abs light came on and off.
hope that helps feel free to ask anymore
