Wheel nut torque
Old Apr 18, 2013 | 01:05 AM
earl's_f20c's Avatar
Originally Posted by sbaylis
Probably a foolish question here but - do you really need a torque wrench to do up wheel nuts? I've always just guessed.
Personally (and this is very bad advice, so ignore) I've been using the 'one vein in the neck, pulling a funny face & a loud grunt' method
Old Apr 18, 2013 | 01:26 AM
sbaylis's Avatar
Haha! It doesn't take a lot of torque for me to be pulling a funny face, I'll have to calibrate...
Old Apr 18, 2013 | 01:58 AM
Nick Graves's Avatar
I'm usually about 1/8 to 1/4 turn accurate with my spider, so I don't always bother with the wrench.
Unless it's a car I'm unfamiliar with.
Then again, it's the simian-sensitivity massive over-tighteners I cannot stand.
Old Apr 18, 2013 | 10:39 AM
MTDNBR's Avatar
Strange people not liking ft/lbs been used for generations. Still buy your beer in Pints don't you.
Old Apr 18, 2013 | 10:46 AM
WinFreak's Avatar
Only because the bar man is still stuck in the past too
Old Apr 18, 2013 | 10:53 AM
MTDNBR's Avatar
Just the bar man stuck in the past is it. I thought the whole country bought their beer in PINTS. Get a life man.
Old Apr 18, 2013 | 11:00 AM
WinFreak's Avatar
You're right the whole country is stuck in the past...
That better?
Old Apr 18, 2013 | 11:19 AM
CHIPPO's Avatar
The method i use is normally in the feel of my arm. but then i have been tightening bolts up all my life and do have good feel. On balance i tighten much more than the recommended torque.
But i really do think most people should use a torque wrench and it really is the best and safest advice that one can give.
But don't forget a torque wrench takes in to account all of the forces that act on the nut/bolt. Thread friction, dirt , dent's, scratch's, lubrication, the fit between both thread parts which all add to the pressure and friction between the components being joined by the fastener. So the worst case would be a nut not actually doing any thing to hold the 2 parts securely together.
Boring !
Mine is 26 fl ounces, please
Is that a pint ?
Or .6 of a litre
Don't dam well check and prove me wrong, its all a guesstimate
Old Apr 18, 2013 | 11:22 AM
yamahaSHO's Avatar
960 in-lbs for me.
CHIPPO's Avatar
Short spanners then
