Wheel offset question
Thought the Spoon were lighter than the OEM ones though? I'd like to see some track testing of the Hi-Spec before I thought about them. Not too impressed with the service either!
I do really like the Dixcels, plenty powerful for track but I went through the last set at a rather alarming rate!
Highside was singing the praises of the DS3000 "endurance" pads and it's safe to say he gave them a good hammering!
According to the Ferodo site, they have a co-efficient of friction of 0.63, the R-01 Dixcels, somewhere around 0.4 or so. http://www.dixcel.co.jp/en/pad_r01.html Do check to see it's an "Apples and Apples" comparison.
Having had a brief drive of Loon's car, I can say the Hi-Spek are mightily powerful, a lot of bite for not much pedal travel.
Thanks Jim, it will be lowered and cambered. Plus, arch liners are meant to be worn out
I couldn't refuse them at the price I got. I can always move them on if some forged fancy wheels come along.
Originally Posted by MB,Jan 27 2011, 11:56 AM
Not keen on the Brembo as they generally use a drilled disc.
Originally Posted by The Loon,Jan 27 2011, 11:58 AM
I had a set of Spoon calipers and sold them - I don't think they are worth the money. They are big and heavy.
Chris.
Originally Posted by MB,Jan 27 2011, 10:52 AM
Is that likely to stick out / look silly / rub with 225 tyres?
I can't find much on the picture search!
Rears would be 17x9 +63
The front wheels are called a face 1 style, the rears come in the face 2 style. The difference being that the rears are slightly concave.
The rears are a very similar fitment to the OEM wheels. When lowered I found no rubbing from the back and thats with a 255 tyre.
The fronts I use are a 215, my coil-over set up is far from firm - Buddyclub N+ -
I found I was getting a bit of rub when pushed hard. 10mins of arch and liner mods per side corrected that. However as Mr Pitts, I have noticed that the BBK 2 piece disc has pushed the offset out further. I haven't driven it yet but may be cause for further mods to the front arch hopefully not as far as flaring but time will tell.
Where are you potentially buying from, I may be considering upping my rear wheel size ?
