Wheel Skimming
Old Nov 30, 2011 | 11:19 AM
Sanchi_ProjectR's Avatar
Default Wheel Skimming
I have a set of forged wheels with a low offset.
I was thinking about skimming them 4mm, but when I measured the amount of material from the taper of the hole to the exit of the stud hole there is only 8mm to start with.
Is it too risky to skim 4mm, considering I will be taking these wheels on track.
Any advice on topic will be appreciated.
Thanks.
Here is a pic just to show you what I mean. Sorry for the rubbish drawing in paint. After the 8mm or 4mm that is the face that sits on the hub.
Also 8mm is an estimated measure there may be more or less material left ±1
Old Nov 30, 2011 | 11:21 AM
loftust's Avatar
Sounds very risky to me!
Old Nov 30, 2011 | 11:36 AM
I agree it does sound risky.
It was just in the back of my mind as a possibility. I never fully convinced myself about the procedure.
Old Nov 30, 2011 | 11:49 AM
rob2.2's Avatar
Banned
how low offset are they to begin with? and what J are they?
Old Nov 30, 2011 | 12:03 PM
Ultra_Nexus's Avatar
Think of it as removing 50% of the material.
Maybe 2mm, but not 4.
Old Nov 30, 2011 | 12:12 PM
I may consider 2mm, but it will always be in the back of my mind.
I'm just interested as to what people think of the idea.
Old Nov 30, 2011 | 12:13 PM
rob2.2's Avatar
Banned
pm replied to mate
Old Nov 30, 2011 | 03:54 PM
mr-pitts's Avatar
If I was using them on track I wouldn't skim 4mm even if I had 14 to start with,I suspect that they have been stress tested at the factory.
Old Nov 30, 2011 | 03:57 PM
r8byb's Avatar
Banned
What's the offset?
Old Nov 30, 2011 | 04:06 PM
Dixon Motorsports's Avatar
I know you doing enginnering degree so Why don't you draw your wheel in ProEngineer and run a FEA on it then you will know if they are strong enough.
