Where to next?
Old Aug 1, 2013 | 08:22 AM
Wellwibb's Avatar
Default Where to next?
Please bare with me, I'm a novice but enjoying myself!
After my recent thread asking what to do regarding my MY00 giving out blue smoke and having a misfire, I have done a compression test myself and got some results.
220psi across all four cylinders.
I have read it should ideally be higher even for a car of this age with 86k on the clock.
Where do I go next with my investigations?
Cheers, will the novice from Solihull.
Old Aug 1, 2013 | 08:29 AM
tozerman's Avatar
220 psi x 4 is good, no worries there. Don't have an answer to your problems though.
Old Aug 1, 2013 | 08:31 AM
Wellwibb's Avatar
So glad to hear that, tozerman! Thank you. So, oil is still being burnt somehow and I have a substantial misfire in the low down revs.
Old Aug 2, 2013 | 08:54 AM
Toms1989's Avatar
Valve stem oil seals?
Whip off the exhaust manifold, if the valves are soaked in oil, 99% certain that's valve stem oil seals.
Old Aug 2, 2013 | 09:42 AM
Wellwibb's Avatar
Would that not give low compression readings? I love how you say 'whip' it off like its a 5 minute job haha. Cheers for the reply, will.
Old Aug 2, 2013 | 10:02 AM
Toms1989's Avatar
No worries.
No mate, that wouldn't alter readings, if it was worn valve seats that would.
Believe me, when you've owned an Astra 2.0 Turbo, the S2000 is a 5 minute job in comparison
Old Aug 2, 2013 | 10:16 AM
Joeh's Avatar
Is your PCV working? Take it off and test it, its a lot quicker.
Put up a photo of your vacuum hose setup
Old Aug 2, 2013 | 11:20 AM
Wellwibb's Avatar
It's a standard setup on a my00 joeh. I'm not sure how I 'test' the pcv? Please forgive my novice attitude towards our wonderful cars.
Old Aug 2, 2013 | 11:23 AM
Joeh's Avatar
Clean off the oil with a tissue and blow through both sides.
One way should feel like its blocked the other way should blow through fine.
If both ways are blowing through, get a new one.
Sometimes the buildup of oil and minor debris can cause the PCV to be stuck open
If you have some carb cleaner, give it a spray
Joe
Old Aug 2, 2013 | 11:25 AM
Wellwibb's Avatar
Right! Thank you, that's the next step towards diagnosis! I would love to find this is the issue and the misfire is a coil. Saves me alot of monies.
