Whiteline ARBs
As per the title...I want to stiffen up my front end without hammering damper settings. Chatted at length to Chris @ CG about it too
So...do I need the adjustable drop links??? Would prefer not to have them...don't fancy greasing them every 10 minutes.
Any info would be great
I'm not sure why I bought mine really; in fact I gave in to peer pressure (I blame Paper Lawyer
How do you define "need"? Droplinks pretty much work, until they snap, but it's not like you'd get any reduced performance from not having upgraded droplinks, unless what you're after is adjustability. I had my rears slightly longer (which reduced the effect of the ARB) for a while, but then got used to it more and adjusted them back to the standard length.
I've greased mine maybe 2 or 3 times per year, and they seem to be fine. But what I would say is that they're noisy; so much so that I was considering buying some standard (or el-cheapo e-bay replacements) to put on for the road.
).How do you define "need"? Droplinks pretty much work, until they snap, but it's not like you'd get any reduced performance from not having upgraded droplinks, unless what you're after is adjustability. I had my rears slightly longer (which reduced the effect of the ARB) for a while, but then got used to it more and adjusted them back to the standard length.
and said the same to Matt via text today!
Seks
Dec 9, 2002 04:05 AM
