Will these fit?
Old May 11, 2011 | 09:27 AM
sanchez's Avatar
Default Will these fit?
As above, will these sizes fit with no arch work?
Fronts: 17” x 8.0” 5x114/5x100 ET48
Rears: 17” x 9.0” 5x114/5x100 ET35 or can get ET48 also
Thanks
Old May 11, 2011 | 10:08 AM
jai's-s2k's Avatar
i have 17" x8 and 17"x9 with 35 off set i had to roll my arch's and adjust the camber on the fronts, but im not on standard ride hight.
Old May 11, 2011 | 10:23 AM
sanchez's Avatar
Ok mate, thanks for that, but arnt the standard wheels ET45, so the ET48 might be ok?
Old May 11, 2011 | 10:40 AM
jai's-s2k's Avatar
yeah i think you might get away with the rear if you are using a 245/40 tyre will be close on the front tho. i would have a look at the US forum on tyre rack they have tryed and tested loads of wheels
Old May 11, 2011 | 11:06 AM
sanchez's Avatar
ok cheers mate, will see what i can find
Old May 11, 2011 | 11:41 AM
Zudzilla's Avatar
Fronts will stick out a tad but no rubbing at standard hight. Rears will need alot of work with +35 offset you would need a +50 on rear for no work.
Standard s2000 offsets are front +55 and rear +65.
hope this helps.
Old May 11, 2011 | 11:50 AM
sanchez's Avatar
That helps alot mate, thanks
Old May 11, 2011 | 11:47 PM
sanchez's Avatar
Theres no way these will fit is there?
17x9 +22 offset
Is it the lower the offset, the more they will stick out?
Old May 12, 2011 | 12:15 AM
p800bry's Avatar
17x9 +22 offset
You got it
k666sdb
Jul 19, 2017 08:32 AM
scottGS2k
Nov 5, 2015 04:01 AM
poo hat
Jul 22, 2010 03:55 PM
s2k_2nv
Jan 19, 2009 06:37 PM
shox
Feb 26, 2007 08:25 AM
