will this work?
Old Jun 15, 2009 | 12:29 PM
YumYumTurbo's Avatar
Default will this work?
im looking at getting a set of rota slips very soon & going to run r888's will 225/45/17 be ok for the front & 255/40/17's be ok for the rear?
Old Jun 15, 2009 | 12:33 PM
E4RTH WORM JIM's Avatar
If you lower the car, you will rub, if not you will be ok.
Just get 215/245 if you plan on suspension mod's
See my sig for pic's
( P:S Rim's are what yanks and gay's say , We call them wheels )
Old Jun 15, 2009 | 12:37 PM
nice one cheers mate, so 215/40 & 245/40?
i was wantin the tires as wide as possible.
has the wider tire been tried & tested?
im planning on lowering the car a fair bit with a set of BC coilovers
Old Jun 15, 2009 | 12:55 PM
No, you want the following:
Rota Slipstreams
Front - 215/45/17 (7.5" +45)
Rear - 245/40/17 (8" +48)
I run Toyo T1R's and have no issues with rubbing, other than the slightest touch from time to time on the front arch liner.
Ron (Hypersonic) run's R888's in the same sizes as above and has had some contact with the rears. This is due to the tyre width/wall being slighly larger. I had the same issues when I fitted Yoko's AO48's.
I do run alot of camber though, which means the tyres don't last long
Old Jun 15, 2009 | 01:06 PM
Rota Slipstreams
ideal mate, i'll take your advice.
just seen s2k's running 255's on the rear in the states & thought it would work.
think i'll order them tomorow
Old Jun 15, 2009 | 01:10 PM
People run 255's over here aswell. Some also used non-staggered sizes.
I can only talk for my own experience. I know these fit without rubbing (other than what I said above). If you roll the arches you could go even wider if you want.
Some have also been known to run a smaller tyre profile, but I haven't so I can't comment
Old Jun 15, 2009 | 01:14 PM
cheers for the info buddy.
im going to try & find out how i can run the 255's on the rear, if anyone has had any experience can they let me know please.
thanks in advance
Old Jun 15, 2009 | 01:15 PM
Higher offset wheel?! or arch modification.
Old Jun 15, 2009 | 01:18 PM
Rota's only come inthe above offset though.
If you buy a set of decent wheels, I:E Volks/Mugen etc. You will get a offset closer to OEM, meaning you can run wider tyres or wheels without making contact with the outter arch.
Old Jun 15, 2009 | 01:19 PM
how much higher offset though?
