Window problem
Since installing my bluetooth handsfree kit and the battery running low (see my other thread) my window no longer opens with one touch. It does work, just not if you push the button once to auto open.
This is the 3rd headache I've had since the weekend. Anyone got any advice?
Thanks,
Karl
Thanks,
Karl
From Spankley's thread
The car has to be started!!
1. push and and hold the window button down all the way until its completly down.
2. when its completely down, let go and push it down again and hold for 2 to 3 seconds. then let go
3. now pull and roll the window up until its all the way up.
4. when its up let go
5. pull the button up again for 2 to 3 seconds.
(after step 2, he said you should be able to hear or feel the motor or something inside reset.)
6. now then your autoscroll should work correctly.
Originally Posted by Bassoctopus,Apr 3 2006, 01:13 PM
In the faq now
The above worked, kinda.
The steps I took were:
1. push and and hold the window button down half way until its completly down.
2. when its completely down, don't let go and push it down fully and hold for 2 to 3 seconds. then let go
3. now pull the window up button half way until its all the way up.
4. when its up don't let go
5. pull the button up fully for 2 to 3 seconds.
Thanks!
Thanks!
