Wiring component speaker tweeters,
Old May 5, 2008 | 12:03 PM
mikdys's Avatar
Default Wiring component speaker tweeters,
Is it the plain wire or the one with the stripe (the instructions show which is + & - on the crossovers but which wire coming out of the tweeters is which)?
Thanks!
Old May 5, 2008 | 01:30 PM
veehexx's Avatar
it doesnt really matter which is which. it will just put the phase out.
aslong as you have the other speakers wired up the same, then it will be fine.
Old May 5, 2008 | 10:46 PM
Paper Lawyer's Avatar
I always use the striped wire as the + but as veehexx says, as long as you are consistent with your approach, it should not be a problem.
Old May 5, 2008 | 11:34 PM
potfish's Avatar
In general there is no standard for whether the striped wire is positive or negative, and I have no idea what Honda uses. Doesn't the speaker have a + or - symbol so you can check?
Old May 6, 2008 | 09:32 AM
mikdys's Avatar
No + or - markings - as the consensus is that the + wire is the one that is marked I'll go with that I think.
Old May 7, 2008 | 04:54 AM
potfish's Avatar
If anything I'd say that the striped wire is more frequently the -ve.
Old May 7, 2008 | 05:01 AM
Bash_UK's Avatar
I found this recently via search! It was yellow & green iirc - try searching
Luke01
Jun 8, 2011 08:44 PM
Ludeboye1
Mar 23, 2009 01:26 PM
s2k aok
Jan 1, 2009 04:40 PM
ade73
Jun 22, 2005 05:41 PM
pikkashoe
Nov 8, 2004 08:37 PM
