Xenon Bulb blown???
Old May 1, 2004 | 12:06 PM
Spanners's Avatar
So what is so 'HID' about blue bulbs? I thought HID stood for High Intensity [b] Discharge [/i].
No discharge in a normal 'hot wire' bulb. Just hot wire.
Old May 2, 2004 | 04:17 AM
Big Cat's Avatar
[QUOTE]Originally posted by scov@home
Old May 2, 2004 | 06:03 AM
Chris Type R's Avatar
[QUOTE]Originally posted by S200 VMC
Then the penny dropped.
Old May 2, 2004 | 07:37 AM
Spanners's Avatar
And this helps a bloke with a suspect broken headlight exactly how???
Old May 2, 2004 | 10:13 AM
Nick Graves's Avatar
[QUOTE]Originally posted by XBy2K
Old May 2, 2004 | 11:44 PM
daern's Avatar
As longstanding readers of this agony column will know, I never use the radio in the S because, firstly, I cannot stand the racket which passes off as 'music' these days and, secondly, I much prefer to listen to the sound of the engine without interference.
Incredibly, your S2000 comes with a "CD player" which (and this is the clever bit) will play any music you like. You can even carry several of these "CDs" around with you so as to allow you pick music that best suits your mood. Clever eh?
There are also several radio stations which carry a good mix of music (Radio 2 is my usual choice) and are available nationally. I have to say that Classic FM is scaping the bottom of the barrel a bit - it's a bit like classical Radio 1 - but each to their own
Old May 3, 2004 | 12:35 AM
MaKSiNG's Avatar
LOL!
Old May 3, 2004 | 12:49 AM
steve_nz's Avatar
Could be expensive. Suggest you get it checked by a (competent) dealer. Had a lamp fail 4m after getting the car and it turned out to be the step-up transfomer - replaced under warranty. About $950 of our money (350GBP to you). Also, those things kick out about 10,000v so don't fiddle unless you really know what you're doing and/or have an LSU and defibrillator available. Now, 3+ years further on, no further problems.
Old May 3, 2004 | 01:01 AM
Big Cat's Avatar
Well, diverts your mind from the problem for a few minutes, dunnit ?
Old May 4, 2004 | 12:27 AM
Spanners's Avatar
Response from ebay advertiser:-
These bulbs are not HID bulbs
